(Fixed) [HOU-3307] DOF wrong distance
I updated from the stable Vray 5.2 from August 3th version to the newset nightly (V-Ray for Houdini number:22132 hash:4344ab5 from 20 Aug 2022 01:37
V-Ray Core 5.20.24 [493f4a2c] from 15 Aug 2022) and it looks like that there are some problems with the distance of the focus point when working with the VrayPhysicalCamera.
Roughly I would say that the Focus Distance is multiplied with something like 10.
I use a Constraint Network with followpath and lookat.
here’s the scene:
Cheers
Tobias
Did you scale the camera or parentent it under a node that is scaled? I hab issues with that before.
I used a constraint network and in it I used followpath and lookat. The thing is that the stable version from 3th of August was working and after the switch to the new nightly it was wrong.
Hey @tobiasroesli ,
I confirm there is an issue that we managed to hit with our internal tests as well - the developers are looking for a fix. I’ll update you as soon as the problem is resolved.
Best regards!
Hello @Gosho.Genchev ,
thanks for looking into it, appreciate it :slight_smile:
Cheers!
Hey @tobiasroesli ,
The issue is resolved on my end with today’s nightly builds. Could you please check if that fixes the problem for you as well?
Best regards!
Hey @Gosho.Genchev ,
I can approve in Nightly (V-Ray for Houdini number:22135 hash:38a13b9 from 23 Aug 2022 01:31
V-Ray Core 5.20.24 [493f4a2c] from 15 Aug 2022) its working.
Thanks for the quick fix :slight_smile:
Cheers!
