(Fixed) [HOU-3697] Bokeh camera setting
The “VRay Physical Camera” → “Depth of field” → “Bokeh” → “Enable” flag is mapped incorrect right?
Shouldn’t the flag it be called “Blades” or “Polygonal Blades” or similar, and should only affect “Number of Blades” & “Blades Rotation”, and shouldn’t disable/enable the “Center Bias” and “Bokeh Anisotropy” setting as they are used even without the “Blades”, when the bokeh is just circular.
Hey @Marcus_C_1 ,
It appears you are absolutely correct. I’ve logged a ticket and will update the UI for next week’s nightly builds.
Best regards!
