(Fixed) [HOU-3803] screenwindow size != 1 and motionblur change resolution
When using a screen window size !=1 and turn on motionblur, the resolution of the render changes in an unexpected ways. Have a look at the attached scene. It appears that this is a rather new issue.
if you turn off mb OR set the screen window size to 1, the resolution returns to expected values.
vray_screen_window_issue.zip (24.5 KB)
Hey @ronald_a ,
The developers are looking into it, I’ll ping you with any updates.
Best regards!
Hey @ronald_a ,
Happy to message that this should be OK now, using the latest stable builds.
Best regards!
Hi @Gosho.Genchev , it seems, the latest stable 20230515 folder is empty and builds from 20230506 don’t seem to have the fix. I did test nightlies which seem to have the fix but would prefer to have a stable build. Probably just a mixup…
