I found some issues with Vray Mesh Light.
It seams that the geo of the mesh light doesn’t respect visibility in vrscenes for rendering when you directly export them into vrscene without abc inbetween.
In gui it respects it.
Cheers
Tobias
mesh_light_vrscene.zip (2.77 MB)
I can’t reproduce this… I’ve rendered your vrscene and mesh light is visible for all frames.
Hello @tobiasroesli From what is to be understood you have set your Mesh light to be Invisible, but when exported as a vrscene and rendered the Mesh light is visible. Please, confirm if that’s the case.
Could you please share with us the scene by going to V-Ray > Pack scene: http://ftp.chaosgroup.com/support/screenshots/houdini\_2024-04-11\_11-55-04.jpg
Also, how are you rendering the vrscene afterwards?
Ok, I got what you mean, your mesh light is visible in the frames when it’s not yet existing. Will fix this.
@viktor_angelov , yes, the visibility is not set in the light itself but in the geo which is fed into the mesh light. It shows somehow the first visibel frame of the geo when it should be invisibel.
I use Deadline for rendering.
The Packed scene is in the attachment.
@bdancer , yes, it’s showing the first visibel frame of the geo but the geo shut not be visibel at this time. So it somehow doesn’t respect visbility.
for_chaos.zip (45.3 KB)
Hey @tobiasroesli ,
The problem is resolved in the latest nightly builds (starting Monday, Apr. 15)
Hope that helps!
