I’ve written a simple usd file that renders fine via husk but by in the viewport doesn’t match the camera focal length to HoudiniGL/VK or Karma.
The stage is set to `metersPerUnit=0.1` and I wonder if that could be the cause of this.
File in usda format here:
#usda 1.0
metersPerUnit = 0.1
def Scope "World"
def Mesh "room_mesh" (
apiSchemas = ["MaterialBindingAPI"]
float3[] extent = [(-50, 0, 0), (0, 30, 30)]
int[] faceVertexCounts = [4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4]
int[] faceVertexIndices = [0, 1, 6, 7, 1, 2, 5, 6, 2, 3, 4, 5, 27, 26, 29, 28, 26, 25, 30, 29, 25, 24, 31, 30, 0, 1, 9, 8, 1, 2, 10, 9, 2, 3, 11, 10, 3, 4, 12, 11, 4, 5, 13, 12, 5, 6, 14, 13, 6, 7, 15, 14, 7, 0, 8, 15, 8, 9, 17, 16, 10, 11, 19, 18, 11, 12, 20, 19, 12, 13, 21, 20, 13, 14, 22, 21, 14, 15, 23, 22, 15, 8, 16, 23, 16, 17, 25, 24, 17, 18, 26, 25, 18, 19, 27, 26, 19, 20, 28, 27, 20, 21, 29, 28, 21, 22, 30, 29, 22, 23, 31, 30, 23, 16, 24, 31]
rel material:binding = </materials/defaultMaterial>
uniform token orientation = "rightHanded"
point3f[] points = [(0, 0, 0), (0, 0, 10), (0, 0, 20), (0, 0, 30), (-50, 0, 30), (-50, 0, 20), (-50, 0, 10), (-50, 0, 0), (0, 10, 0), (0, 10, 10), (0, 10, 20), (0, 10, 30), (-50, 10, 30), (-50, 10, 20), (-50, 10, 10), (-50, 10, 0), (0, 20, 0), (0, 20, 10), (0, 20, 20), (0, 20, 30), (-50, 20, 30), (-50, 20, 20), (-50, 20, 10), (-50, 20, 0), (0, 30, 0), (0, 30, 10), (0, 30, 20), (0, 30, 30), (-50, 30, 30), (-50, 30, 20), (-50, 30, 10), (-50, 30, 0)]
uniform token subdivisionScheme = "none"
def Camera "camera"
float2 clippingRange = (0.1, 10000000)
float focalLength = 5
float focusDistance = 5
float horizontalAperture = 19.2
float verticalAperture = 10.8
matrix4d xformOp:transform = ( (1, 0, 0, 0), (0, 1, 0, 0), (0, 0, 1, 0), (0, 15, 30, 1) )
uniform token[] xformOpOrder = ["xformOp:transform"]
def "materials"
def Material "defaultMaterial"
token outputs:surface.connect = </materials/defaultMaterial/default_usdpreviewsurface.outputs:surface>
def Shader "default_usdpreviewsurface"
uniform token info:id = "UsdPreviewSurface"
float inputs:clearcoatRoughness = 0.1
color3f inputs:diffuseColor = (0.8, 0.8, 0.8)
float inputs:roughness = 0.2
color3f inputs:specularColor = (1, 1, 1)
def RectLight "area01"
float inputs:exposure = 1
float inputs:height = 1
float inputs:intensity = 1
float inputs:width = 5
float xformOp:rotateX = -90
double3 xformOp:translate = (-10, 20, 1)
uniform token[] xformOpOrder = ["xformOp:translate", "xformOp:rotateX"]
def RectLight "area02"
double3 xformOp:translate = (-20, 20, 1)
def RectLight "area03"
double3 xformOp:translate = (-30, 20, 1)
def DomeLight "light_dome"
def DistantLight "light_distant"
custom float houdini:guidescale = 10
bool inputs:normalize = 1
float xformOp:rotateY = 90
float xformOp:rotateZ = 45
uniform token[] xformOpOrder = ["xformOp:rotateZ", "xformOp:rotateY"]
def "Render"
def RenderVar "var"
uniform token dataType = "color4f"
custom string driver:parameters:aov:channel_prefix = ""
custom int driver:parameters:aov:clearValue = 0
custom token driver:parameters:aov:format = "color4f"
custom bool driver:parameters:aov:multiSampled = 0
custom string driver:parameters:aov:name = "Beauty"
custom bool driver:parameters:aov:vray:color:color_mapping = 1
custom bool driver:parameters:aov:vray:color:consider_for_aa = 0
custom bool driver:parameters:aov:vray:color:denoise = 0
custom bool driver:parameters:aov:vray:color:derive_raw_channels = 1
custom bool driver:parameters:aov:vray:color:enableDeepOutput = 0
custom bool driver:parameters:aov:vray:color:filtering = 1
uniform string sourceName = "C.*"
uniform token sourceType = "lpe"
def RenderProduct "product"
uniform token aspectRatioConformPolicy = "expandAperture"
rel camera = </camera>
uniform float4 dataWindowNDC = (0, 0, 1, 1)
custom bool includeAovs = 1
uniform bool instantaneousShutter = 0
rel orderedVars = </Render/var>
uniform float pixelAspectRatio = 1
uniform token productType = "raster"
uniform int2 resolution = (1920, 1080)
def RenderSettings "rendersettings"
uniform token[] includedPurposes = ["default"]
rel products = </Render/product>
custom float vray:SettingsImageSampler_progressive_maxTime = 1
Cheers!
