(Fixed) [HOU-4763] Can't get 16bit half primvars to work
Float and double primvars render as expected, but half doesn’t seem to work in VRay (it does in Karma).
Would this be possible to support?
VRAY_RFE_halfFloatPrimvar.zip
VRAY_RFE_halfFloatPrimvar.zip (80.3 KB)
Hey @Dan_Andersen ,
Thank you for the report. The issue is logged under HOU-4763, and will be fixed starting with tomorrow’s nightly builds.
Best regards!
That’s great - thank you :slight_smile:
Btw, @Gosho.Genchev , will this fix be available in the stable 6.2 nightlies ?
@Gosho.Genchev .. A gentle ping. We’re stuck on 6.2 stable for now, so I’m curious if this fix will find/has found its way into this branch?
