(Fixed, Open) [HOU-1712, HOU-1791] Error messages
Ok success !!!
The installer was defaulting its packages path to my 17.5 install which is only there for compatibility testing.
Thanks for baring with me.
Best,
Jim
Glad to hear you got it figured out. We added the installer to simplify things but due to the way 3-rd party plugins are loaded in Houdini, there’s a few things that could go wrong and it may be hard to figure out what’s causing the problem. On the flip side, it makes swapping plugin versions incredibly easy by simply changing the path in the package file.
Best regards!
Yep, one of the issues was simply that I am overloaded, and setting up machines ends up taking ages :slight_smile:
So where is the *.json file stored? and how does Houdini get at it?
If you used the installer, it’s under the Houdini install folder (For me: C:\Program Files\Side Effects Software\Houdini 18.0.391\packages)
V-Ray for Houdini itself is installed under C:\Program Files\Chaos Group\V-Ray
Houdini knows to check this folder for any package files and includes the specified environment variables inside.
Hope that helps!
Thanks… so I just double checked and the help is not opening…
Is there a way to edit the json file which might address this? as per previous convos?
try add ${PATH}; before ${VFH_HOME}/bin in .json
{ “PATH” : [
“${VRAY_APPSDK}/bin”,
“${PATH};${VFH_HOME}/bin”
Boom. Thank you !! Works perfectly. I was scanning through the json file for that, but my eyes just ended up swimming after a while.
Hi everyone,
deleting the H18 folder from Documents solved the issue for me.
Cheers, Ambrozie
Can someone fix this issue. It is a really simple fox as pointed out by DmitriiP
{ “PATH” : [
I just installed the latest build and the problem is still there.
Hey, Jim,
starting with tomorrow’s builds, this should be resolved.
Best regards!
Hey, all,
apologies for my previous message - turns out appending ${PATH} produces a segmentation fault crash on my end. It’s awesome that this patch works for some of you - however, we’ll look into this on our end to make sure we don’t ship crashing builds and update the json file once we have a stable solution.
All the best!
