(Fixed) Reflection/Refractions Masks not working
It seems reflection/refraction masks are not working as expected.
Reflection/refractions basically disappear when there is anything other than * in the mask field (even if you put a space behind the star).
I hope this can be easily fixed as this is extremely high priority for us.
We are getting some funky warnings in the console as well like this:
sphere_chrome void __cdecl OP_Parameters::evalStringT(class UT_String &,const class UT_StringRef &,int,double,int) const: Invalid parameter name “”
V-Ray for Houdini, build 8210 / 0cbf912
V-Ray Core, 4.30.03 / a392470c from Sep 1 2020
Could u send me a scene showing the issue and the warning?
Sure can do…this is not scenespecific, it happens always.
when I hit render in the attached scene, the right sphere should not reflect the grid but the left sphere and the light. Instead it renders black here.(because it has a fully reflective material).
refl_refr_mask_issue_vray.zip (30.3 KB)
Tnx, I’ll fix this; you could add “Object Properties” to the “sphere_chrome” as a workaround.
Hey @bdancer , checked the latest nightlies, issue seems fixed. Are we good to go using it?
Yes, sure.
