I remember having posted this before but for some reason can’t find the threads.
In general, Corona’s exclude/include lists still lack some options that would make them more convenient to work with. In addition, except for the list dialog, they have different options:
- in the Distance Map, we have a “+” and a “-” button, and the RMB ‘clear list’ command
- in the CoronaCam and the Mask render element Mask, we have a “+” button and the RMB ‘clear list’ command - for some reason, there’s no “-” button here
Please can you make sure they all have the same functionalities across the entire range of Corona features and objects?
And please can you make the ‘Clear List’ command a bit more obvious to the user? It doesn’t make sense it’s available as an RMB command on the “+” button but not on the “-” button. How about introducing a “X” button, so it’s quickly visible for beginners for example?
Also, if you want to check what’s included in a RE Mask’s list, for example, there’s no way to quickly select all objects. When the list contains 1500+ objects the only way to find out is to open the list and wait… wait… wait… for larger scenes and then go through a list of thousand of names and try to find the one you’re looking for.
A good solution would be to add either icons or an option when you RMB click the list which would let you:
- select objects in that list
- create a selection set based on the objects in the list (named ‘exclude list selection x’, for example)
Exclude/Include lists and their limited options have been a topic multiple times, I really think it’s about time to make sure they finally feel complete in v2. Thank you!
