flaky new max behaviour
in the past week my max (2016) has begun occasionally hanging while saving a large scene.. at the same time, so probably related, if i try to open a second copy of max, it hangs at the splash screen and never loads. i find rebooting my machine seems to get things back to normal for a while. im not maxed out on ram or anything. specific pair of problems ever noticed by anyone else?
try rename the Enu folder to Enu_Old, then when you next start max it creates a fresh Enu and see if your problems disappear
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Max-Design.html
thanks, ill give that a shot.
if you updated with the latest gpu drivers you will see these kinds of crapping things happening, had to revert back two versions earlier
