Revit
When in VR the entire model flashes on and off and never settles. this is not the same as two materials being on top of eachother. the entire model is unusable when in vr. If i turn off VR, everything is fine in the window. I am not really sure what is happening.
I have video but it is restricted from uploading. see the link below.
https://drive.google.com/file/d/1rVfjKD8RRjDKQn1h0UVc289gPGxnd2ii/view?usp=sharing
HTC Vive - fully updated steam client & Steam VR. no beta opt-in
Windows 10
GTX 1080 driver version 398.11
32GB DDR4
i7-8700
Hi @vrklingner & welcome to our forums!
Thanks a lot for your report. Does the same issue also appear when you open the Revit sample projects and enable VR or does it happen only with this model?
Please also send Feedback with logs files using the Feedback button on the Enscape ribbon.
Thanks in advance!
Wild guess but is it below the zero plane?
I don’t use Revit but in SU the ground can cast a shadow and if your model is below it you get something similar.
feedback sent with the log info.
used a sample project and have the same results. i went back and installed some gpu drivers from march and it also has had no change. its possible its a vive driver, but i havent figured out how to roll those back to an older version yet to test.
