Flashing in the sequence
Hi there,
After trying Vantage for a while, it feels really useful and the rendering is so fast. But when i used the scene from “Building Utopia”, I found that there are lots of flash in the sequence I rendered. it almost flashed everywhere in every single frame, especially in some specular, reflection roughness and some self illumination area, the flash i think is unacceptable.
Though I’ve tried to improve the samples to 10000, nothing seems to have changed, then i can not find any options to fix this problem.
I post two images bellow, it just one of the flash and there are also plenty of flash in sequence. So, what should i do to kill these flash?
Happy new year.
I was going to suggest that this is caused by the denoiser as discussed in other recent threads, but it looks like these are raw images. Are they? If the denoiser is off, then this must be a “firefly” artifact boosted by the Bloom post-effect. If you turn off Bloom before rendering the sequence I expect you will have a single bright pixel there, which would be somewhat better but probably still quite noticeable. Now why would the pixel be so bright - it might just be the perfect angle to reflect the Sun or it might be a shading bug… We’d need to investigate to find out. All this applies if it is a raw image - otherwise it must be a denoiser artifact.
The only way to remove bright denoiser artifacts would be to set the denoiser to 0 (or “keep denoiser = off” in the sequence dialog). Even at a low slider value the blending is performed with preference for the denoised pixel if it differs a lot from the raw value.
I followed your suggestion and turned off the denoiser completely. It has indeed improved a lot, and I also saw a lot of material details that I can’t see when the denoiser is on.
Thanks.
