I thought it would be easy enough render an object with an entirely flat opacity/visibility but it wasnt’t. I am trying to get 3d trees and people to be rendered as flat objects but with flat opacity (like the one in the reference picture).
Has any of you got an idea how to achieve that kind of a result with 3d objects directly from max without using 2d planes or render layers?
Thanks in advance!
yes because it was done in photoshop, I am trying to get the same effect with 3d! I know it sounds crazy but its actually is easier to place the trees in max and after getting the approval from the client for these sketches just hitting render with final materials on the trees that you have already placed.
Actually its all happening because of the my client’s request, they want to make their first presentation to their client using similar images as the sample.
Oh right, sorry! Not sure if it’s possible. You could use a self-illuminated material but you’ll get some overlapping tone happening on the branches of each tree, or you could render out a mask/alpha for the trees in a seperate pass to then use in photoshop, but then you don’t get the overlapping between different trees.
Yep - messed around with self illumination and opacities but we had no luck when we were trying this. I think I may have even posted a thread on this a year or two back…let me look.
You may be able to get the effect you’re looking for with RPC trees? I can’t think of any way, with the available shaders, to achieve that result with a 3D mesh.
I’ve tried this many times and finally found a workaround that seems to work most of the time.
You have to put a 50% opacity material or whatever to the objects and in the vray properties uncheck “visible in refractions” parameter. Try it.
gagui, I did some tests with the method you said on the people and it came up with some nice results however as you said its not perfect but definetely better than spending extra time on them in photoshop.
I really do think its necessary have some kind of an option in vray or an outside plugin to create this effect.
how about apply a vray light material set at 1 (or whatever looks white)
whack a vray colour map into the opacity slot and adust
vray properties → uncheck all that GI affecting stuff.
I havent actually tried this, may be a complete faliure
