Hey, I have a fleet of near identical ships. I would like to use the same wake simulation for all ships. Is this possible? When I copy the simulation around it renders only the animated mesh, not the foam/splash.
Also is there some way for them to all use Ocean rendering and blend :O? Or does anyone have any suggestion on how I would go about this.
the foam is not rendered by the simulator, because many users create foam by its own particle systems, so the foam shader is a separate object. the foam is rendered by these half-sphere objects called PHXFoam, create one and pick the simulator instance that contains the foam to be rendered.
however, the shared ocean is more problematic. if you have no closeup views, you can render one simulator in ocean mode and other simulators in cap mode.
