Hi
For the AA type, instead of adaptive subdivision, maybe try DMC and 2,8 or perhaps 3,12
For the filter try quadratic
For lighcache switch on retrace. And your passes is set to 6, are you using an AMD CPU? Set that to 0 to automatically use all cores for the lc passes
Depending on your glossy material subdivs, the DMC of 3,12 may introduce some noise in your reflection pass in which case you may need to increase the material subdivs of glossy elements
For IRmap the medium preset should be fine. Set interp samples to 40
