flickering on animation
Just doing a animation, we have several objects flying in (appearing using transparency) however we are getting flickering when ever these objects come in… is there any way to stop this?
Not sure if objects have to much reflection or should turn some settings off on lights?
this is a small snippet example, see when table flys in at end
Thanks in advance!
Hi could you send us an example scene here or through our contact form.
If you are able to include the rendered frames as well that will be great.
Also what software do you use to build your scene (for example 3ds max)?
My guess would be that the GI changes too much as these objects fly in, and as it is so fast this is causing a flicker before it resolves.
I’d also guess there’s no quick fix for it; rather you’d probably need to render the objects that fly in separately, with a matte shadow, and composite them.
Or maybe I’m wrong and there is a button I missed…hope so :slight_smile:
