Flickering paused smoke
I have a segment of an animation that just shows a paused section of smoke (it goes to the end end then stops and holds the frame)
In this segment of video you can see how the smoke holds, flickers, and then holds again.
At first I thought it might be different machines so I re-rendered all on the same machine,
It does this regardless of the quality settings I use for GI.
Can you shed any light on why it might do this?
Shouldn’t happen, can you send the scene over?
Hey,
By any chance are you using a V-Ray denoiser? Does it reproduce if you turn it off?
If you increase your Max transparency levels from the V-Ray options does it get better?
Cheers,
It seems as if this is fully about adaptive lights - it doesn’t happen with the full light evaluation mode. Do you still want to see the scene or is it not worth it?
Oh yes, it would be important for the V-Ray guys - if possible,please send it over.
Cheers!
I have sent it off to support with reference to this thread… I hope it helps!
