So if you use brute force and LC, this should not happen. What were your settings? In LC you can chose use camera path and save the cache from first frame into file, then switch to using that cache for entire camera move. Try that as an option
@mossawi , can you let me know your V-Ray/3ds max version? When setting the BF/LC, please also set Light Cache to Animation preset (or use Subdivs: 3000/Retrace: 8 ). Alternatively, you can send your scene to support@chaosgroup.com for further investigation. Thanks!
In the file you shared, it appears that you are, indeed, using the Animation preset but the Retrace option is turned off. Please make sure to turn it on again, and that should do the trick (at least it is working fine in my test - see sample). Let me know if that helps.
