Flickering Surface and other liquid-related problems
don’t forget that the gizmo by default cuts the content outside, not the internal one. the glass case is very misleading, because the common sense says that the liquid is inside the glass but it is not.
topologically the liquid is outside (it is NOT in the glass mesh), and you have to use the “invert gizmo” option
yeah, i tried that but gave me the same result as without gizmo. do you need a screenshot or so?
yes, would be good. attach both the results with the render settings visible in the image
It is the same scene as I posted in the thread about water is disconnecting with finer grid.
Here are some screens:
seems like your liquid does not penetrate into the glass, this is an essential condition to have working gizmo.
why i think this? in the first image you are rendering in mesh mode,and the glass walls are visible. see this section of the vray help, there you can find an explanation why the liquid must overlap the glass. your image looks like this example , but it should look like this if the liquid overlaps the walls
btw the gizmo option does not affect the mesh rendering mode, it is only for the implicit surface.
