Hi, I think corona needs something like vrays “subpixell mapping”.
In scenes with small lights and many sharp reflections is imposible remove noise in reasonaible time.
I have tested simple scene with1 light and some glass. rendertime is more than enough for that simple scene and i didn’t find the way to resolve it.
Why are you rendering frames based on time? This will give you different noise amount in every frames, you should be rendering based on passes to achieve an uniform noise result.
Thanks, now im testing it by your suggestions, today i will put here something.
to Rawalanche: i know, subpixel mapping is “non realistic” feature and sometimes ruin quality of details, but without it a have to hugely increase AA, what mean very long rendertime.
its better but still not clear, im testing this scenario because i did few animation inside dishwasher with vray and i would like use corona in future but im afraid of rendertime in this type of scenes.
vray without subpix is disaster. (that camera shake is some bug in max2014)
this is with subpix enabled- many reflection is missing, but nearly without noise
if i compare without Subpix then is Corona clearly better than vray but because of rendertime i have to use vray +subpix
i will try with lower maxsample intensity today
I agree with rawalanche on this one - lowering GI to AA ratio is the way to go. Changing MSI will probably have no effect on the fireflies. Introducing such huge face factors as subpixel mapping would go against the basic Corona philosophy: high-quality results with minimum number of algorithm-related parameters
Anyway, while I don’t have answer for this, I wanted to mention sub-pixel cuts-out highlights only by default, you can keep sub-pixel and high highlights by introducing more samples per material (goes in conjuction with AA though). That’s only on side. It was extremely helpful to me on handful of animations.
Lower trace depth (for reflection and refraction) should help with this though, I know I never had more than 4 in any sort of animation (with Vray). I don’t think either MSI is contributing factor, it’s simply complicated reflection, since it bounces quite few times.
Please, don’t start to talk, again, about VRay sub-pixel mapping! It was my devil!!! ehehe… XD
If someone knows my discussion with Vlado, he can understand what I want to say.
In VRay 2.x it was near to be impossible render an interior shot with sub-pixel mapping on! Especially with glasses and strong highlight!
The rendering time became so huge (from x3 to x5 time!)
But, if we introduce sub-pixel mapping in Corona and we can speed-up the rendering (from x3 to x5 times at the expense of quality) maybe we can try to think…
Especially in animation.
Rawalanche: internal reflections was enabled in vray version.
Yes you are right i dont say it exactly. I didnt want very degrease MSI beacuse before i tried MSI in other scene and i realized that MSI has more influence on GI/reflected GI than sharp reflections, so
Look on this comparison: with MSI 10 vs 1
GI/AA=3
Tent width = 2
Reflections are very slightly changed and also noise is the same. what is different is wall behind light (GI influence)
I dont want talk against corona or vray. I would like use corona in future so thats why i want to resolve it. (critical feedbeck is needed for achieve maximum quality of product)
My latest discovery:
Looks like something is wrong with disabled caustics for the glass material. It makes rendering time much much much longer and there are more random white dots on the walls.
MSI-10
glossines=0.999
big difference, who would predict that, unfortunatelly kill too much light, maybe MSI15 would be fine.
now it could be only litle less blured- 0.99999?
