FLIP emit from particle
Hey
Is it possible to emit from particles as source. Would be interesting to make large scale directed splash.
yes it’s possible particularly. the particles have the option to use shape, this option represents them as geometry objects and the geometry sources are supported from the very beginning. using shape is slower than using the particles as point sources, but if the count is not too big the slow down is negligible. the point mode is still not supported because some changes are planed in order to make the particle behavior equal in max and maya and the support will be added after the reforms are finished.
