FLIP fluid mixing
Hey guys
Is it possible to mix phoenix sources when using FLIP, similar to what you can do when using the SPH solver.
I tried the same technique of RGB output from the source object but no luck as of yet.
Build: phoenixFD_adv_22000_max2014_vray_24_x64_25505
Adam
the flip solver is still under construction and there is no rgb channel supported yet. hopefully we will add it soon.
