Hi Escape Team,
the doing of Normal Maps needs to be improved.
Following Features regarding Normal Maps would help a lot:
Flip Y Normals
to Ez fix normal maps that are exported for DirectX instead of Open GL
see here
Import 64 Bit Normals
Importing 64 Bit PNG Normal Maps dont work in the Material Editor. They get always interpreted as Bump Map.
Intensity of Normals
There is a slider but he is just doing nothing.
Thank you all
Hi @H.Jakob
Thank you for bringing this up.
Flip Y Normals
I have forwarded your request for a button to Flip the Y axis for normal maps.
I will test and advise with our developers regarded the 64 bit maps and get back to once I have an answer for that.
I had seen your feedback report as well and noticed you are using Vectorworks, this looks like this is a bug and the normal map intensity parameter on our side is not correctly mapped to the bump strength in Vectorworks.
The result is that changing it in the Enscape Material Editor simply has no effect indeed.
Our developers are informed and are working on resolving this.
A workaround for now would be to use the Vectorworks Material Editor to change the bump strength of the bump shader until it’s fixed.
Hi @H.Jakob
Thanks again for mentioning these topics!
After further testing it seems that this result with the importing of the 64 bit normal is a bug in our Material Editor and our developers are working on resolving this in our next version as well.
