floating model - how to solve
here I have opened the Revit model in Enscape, and this is the default presentation. The model appears to be floating above the ground plane, and I cannot find any obvious means to lower the model or raise the Enscape ground plane/HDRI/Background. can anyone please advise on the correct procedure to correct this condition, which I also noticed happened with a SketchUp model.
Thanks for any help.
Hi @trombe
A skybox is always infinitely large. You can imagine it as a sphere encompassing your whole scene.
If you look at your project from a distance like you have, it will always look like it is floating.
As seen in my image, it will look more correct from within your project however.
If you would like to have a better representation from a distance I would suggest to model more of the environment.
When using a skybox it’s important that the eye elevation and target elevation in the photo are the same elevation as the project view in Enscape. For example, you can’t be on the hundredth floor of an office building and use a photo taken at ground elevation for a skybox. Likewise you can’t use a photo taken on the hundredth floor as a skybox for an Enscape view in the lobby on ground level. Likewise, it appears your photo and your project have two different eye and target elevations.
thank you both for your help
regards
trombe
