Floor Generator Quick Question
Hello all!
I recently started using Floor Generator and have finally reached some issues I cannot figure out. Whenever I import splines, even as separate files, all of my instances of floors will all have the same material when I apply the material from the slate editor, even when I am not copying modifiers.
I am importing each floor shape individually and using individual floor generator parameters. Any assistance is greatly appreciated!
Josh
Hi Josh,
It’s very annoying! But it’s optional:
In the material editor, in the “Options” Menu, 1st or 2nd option is “Propagate Materials to Instances”, turn it off!
Cheers,
Francisco
Ugh such a simple fix! But it was exactly what I needed. Thank you so much Francisco!
Not sure if I understand this request correctly, but maybe Corona Multi Map in “mesh element” or “material id” mode would help too?
