Floor Generator script + multi/sub-object shader
Hi, I know this is related to a 3rd party script but as I imagine Corona has a vast amount of archviz-users I thought to mention it.
When I use the Floor Generator script to “fetch settings” from an already created floor, in order to make another floor identical to the first, my multi/sub-object shader removes all but the first slot. Very annoying, and
I don’t believe the cause to be identical material IDs as I only use say 1-10. Afaik the script uses much higher values (50+).
Edit: Also happens when creating new floors.
Regards
Why do you think this is caused by Corona? How is Corona involved in the problem?
any progress here? If you cannot provide more info, I will have to close this report.
