i have a strange issue while simulating boat with phoenix fd. The particles in viewport look fine but when i render the image the foam cuts suddenly (Image below). What can be causing that? Also the foam behind the boat and on the other side does not render too (the visible “foam” in behind the boat is actually splashes).
Which versions of Corona and Phoenix FD are you using?
Thanks,
Rowan
I’m using Corona 6 and Phoenix FD 4.30.00 for V-ray 5. I have also checked and everything renders fine in vray.
Thanks for the info, would you be able to provide your scene so we can investigate it please?
Instructions on how to do this can be found in my signature.
Cheers,
Rowan
I have sent archived scena and one *.aur file with the liquid simulation via the dropbox uploader. Is that ok?
Thanks for the files, I have done some investigation and can confirm the issue.
As of yet we are not sure what is causing this so I have sent it on to our devs for further investigation.
I’ll let you know when I have some more information.
Cheers,
Rowan
(Internal ID=587885809)
Hi!
any updates on the issue?
As of yet I don’t have any updates on this. It is logged in our system and with our dev team.
I’ll let you know when I have some more info, but as of yet I can’t provide any timescale.
Cheers,
Rowan
Tested and working with Phoenix 5 + Corona v10 daily build.
