We have a truck going through a car wash. So we have a grid linked to the truck. Foam stickiness is set to 1000. The problem is particles also stick to the stationary floor and move with the grid. Why do they move with the grid.
Also we tried stationary grid but foam won’t stick to the truck anymore. Can you try both ways Thanks
Got the scene, though the simulator with the truck seems to be positioned in the middle of the ground geometry and rotated and it is really small?
There is another hidden static liquid simulator. Which one should we sim?
hi,
the one that’s not hidden one
Could you explain about this “simulator with the truck seems to be positioned in the middle of the ground geometry and rotated and it is really small?” is it a wrong scale?
Yes, wrong scale and wrong orientation, but even if I rotate it and scale it - the emission of the sources is not matching correctly. This is how it looks when I open the scene.
