Hello, I wolud like to add more volume to the foam so the foam particle are not so tight together? I have “b2b” on 100, should I change this to 0? also “variation up” on 5 and splash and mist drag on 6 and 4. I’m wondering if any of these values would make significant change or should I change them all to get better results. I would run a test from scratch to find out but have no time, so any tips would be very useful, thanks!
Do not return B2B to 0 - it is the force that keeps the volume of beer heads, so you need to have it high, but not too high - do not go above 300-500, or the foam will stick together too strongly.
Once you have B2B, you need to increase the foam amount and that should increase the volume,
Hope this would help!
