Focal range
Hi :slight_smile:
At the moment i’m experimenting a lot with the videoeditor functions, and one thing i find hard to get right is the DOF effects. If you turn the effect just slightly up, it becomes very hard to keep an item completely in focus, simply because the depth of field is so narrow. in most use cases the effect is used to seperate a background and a foreground, but i’m never able to get more than a couple of centimeters in focus if i want a blurry background.
Could You somehow implement a “focal range” rather than a “focal point”… for example two sliders controlling a far- and near point of the range you want to keep in focus… I know this isn’t how a camera works, but it would be VERY useful, and give a lot more control over the images :slight_smile:
I glad that you write about the Enscape DOF, since it’s on my list to request since a long while. Finally I don’t used the Enscape DOF and start to use post DOF effects. The focused range is to narrow for my need too.
Additional I could imagine a little flag option like “fore ground only” for the DOF. Often I arrange some objects in the foreground for some little DOF in the foreground only and the important parts of the scene in mid and far range are sharp. Attached a typical z-depth I use for post DOF.
Back to the extended DOF range. :wink: Here an example how I do it per post work DOF, the range of interest is flattened. So, manual it’s quite easy, so I hope it could be easy added to the Enscape DOF functionality. :wink:
There were some bugs regarding artifacts and focal sharpness that have been fixed. Will be released in thw next preview and official release.
Let me know if that helps. I think it should - i would like to avoid purely artistic parameters that achieve a DOF that is not possible with any real camera. If users accidentally change those, they end up with images that subcontiously look fake without knowing how to fix it.
Currently there is no depth image exported for video, and so no workaround for animation. This would be a welcome addition.
z mask would be handy for post work.
we’d prefer camera like fstop and range but a how much blur instead of fstop is fine too.
@Thomas_Willberger That’s why it is called artist. I still believe on the artistic free dome. :wink: Will the missing DOF effect applied to the Mat ID channel at the next versions too? Without DOF the mat id is useless in this cases.
Vray or post work DOF plugins allowed me to get a rael camera DOF, but often I setup an extended DOF because my clients like it. Here an old final image from a project. The designers can clearly show the designed parts, but a little feeling for the depth of the space is added.
EDIT: One more thought for the topic - maybe a “fore ground only” option would help to avoid the doll house effect that can be seen from time to time at the showcases. So, maybe this option wouldn’t cause strange effects, it would help to avoid artistic mistakes. :wink:
I’m not suire that going for a “camera” approach to DOF is the ideal path: I think a closer representation of the human eye would be better where the ‘range’ of clarity is greater the further from the eye the target is. (And inversely, the narrower the band of clarity, the closer the target is.)
Thanks for all the inputs! :slight_smile: it seems like i’m not the only one with some challenges working with DOF :slight_smile:
i’m very much looking forward to the next preview to see how the DOF system behaves here! exciting times :slight_smile: I’m still hoping for more control over the focal range, as I maintain my view that the current system isn’t very usable without a wider focused area.
in this example, I cant even manage to keep the little flower in focus, let alone the nearby grass, if i want a somewhat blurry background (the DOF slider was set to only 7%):
https://1drv.ms/v/s!AtDmbdAqfyUvgZNiIcCPmyirGHOO3w
This real life example was taken with a rather extreme f1.4, and it has a very blurry background and still a wider focus area than my test :slight_smile: so it seems that enscape isn’t acting completely like a camera at the moment?
a depth mask for animations like @renderwiz mentioned, could be a temporary solution as well, but having the control straight in enscape would be awesome!
The eye is a camera and obeys to the identical optical laws. You can replicate the eyes DOF properties by replicating it’s sensor size, aperture length etc. All these parameters boil down to a scale of the CoC (circle of confusion) which describes the bokeh radius w.r.t. the difference to the focal plane.
@Herbo : You are right, that’s what I tried to say. The current Enscape implementation has a little bug that accidentally blurs the area in focus in some cases. It will be fixed in an upcoming preview.
@Thomas_Willberger
ahh, perfect! Can’t wait to try it out :slight_smile: i hope this will overcome the current problems with DOF. Do you have a timeline for when we can expect a new preview?
I understand that, but what is seen and what is perceived can be two different things, for example “tilt-shift”, “focus stacking”, etc.
You guys are really good at simplifying the complexity of things; I think that if you were able to define both how close something starts to gets fuzzy and how far before you loose focus without having to know about focal length/ f. stops and aperture it would be very user friendly and give a simple control to users with no interest in photography.
I think to that the human eye and brain are not only a camera. So, we have the impression that anything is sharp, since the focus is at the point of interest always.
If we would try to simulate a photo camera only and this should be done fail proof, than Enscape should read the lens length from the used view and support a f-stop parameter. The critical doll house effect is caused, if the DOF slider is used to much, also if a wide angle lens is used and it wouldn’t never show so much DOF.
For now I’m curious for the next update, maybe the depth range will be better.
Look forward to this, recently had this issue myself where it was struggling to focus due to the small focus distance.
It’s now included in the latest preview. The in-focus area should be accurately sharper and the overall image is more stable and has less artifacts.
@Thomas_Willberger Are you sure? At the preview download page I can read:
  • Version: 2.3.3.1493-g1875bae
  • Released: September 21, 2018
  • Enscape Asset Library
  • Improved Depth of Field
Yes. Whats wrong with that? Looks like the right version to me.
I understand you that there is no improved DOF at the latest preview , but the preview description show DOF on it’s list. I was not sure what you mean. Now I suppose you mean, an extended focus range isn’t included, but a better general DOF quality.
Please keep on a better focus range too.
Sorry, there was a typo. “It’s not included” should be “it’s now included” :S
It is sharper now and has less artifacts.
I will refresh the topic :slight_smile:
I think two sliders for depth of field would be the perfect solution.
Currently, I can not cope with the desired effect for buildings - the focus bar is too narrow :frowning:
