Might be doing it wrong but i am unable to adjust the camera fucus distance through the parameter in the camera object. Dof is enabled in the camera tag only, not through render settings. No matter the distance set or object assigned to focus object slot, the focus is always at the same spot. However, if i enable dof in the render settings and set the dof override the focus distance is adjustable through the distance parameter in render settings.
Seems almost like the focus distance in the camera tag is locked to 100 cm (default value) in render settings) even if dof override is not enabled and distance should be controlled through the camera.
