Focus Distance
Ctrl + Alt + LB Doesn’t work when trying to change the focus distance in the viewport in the current version. Tried multiple files.
From the changelog for 1.4.0:
“- Improved “Change focus distance” shortcut behavior - works like a virtual slider instead of duplicating the Pick focus tool”
In other words it no longer behaves like the focus picking tool you can select from the top toolbar. Instead you hold the keys and move the mouse left and right to smoothly change the focus distance, regardless of what object is under the cursor.
