Hope this is an easy one, I’m working on the materials for an orange indicator light on a car project. For the life of me i can’t get the fog colour on the light bulb to be Orange.
As you can see in the attached image the colour picker is set to orange yet the rendered image is yellow. I’ve tried fog intensity’s extremely high and low with the same “colour” result. Shifting the colour picker along either seems to snap to red or yellow no in between orange. Also exit colours on/off.
try setting the diffuse colour to black, then you can make the refraction colour orange as well as the fog. might even work without fog, but I guess that’s up to you.
id set the exit color back to default. i usually put diffuse and fog as the same then crank up the fog to something like 0.2 or 0.3 all depends on the look you need
Thanks for the responses. Upping the amount and setting diffuse to same orange did it. Still quite a bit of yellow in the fog but the orange diffuse masks it enough.
