it seems that fog is just added in a even way all over - shouldn’t the view not be quite clear near the camera and more faded the longer the distance?
thanks
jorgensen
thanks
jorgensen
That’s an optical illusion, the optical density for shorter distances (near the camera) is lower. You’ll notice that if you compare a far away object with fog enabled with an object that is near to you.
