No matter what I do I dont even come close the the mood of the picture.
I thought a noise in the Fog Transparency > Texture slot could bring me to the goal but it seams that nothing happens if I use a Noise.
Did I forgot something or do anyone know a Tutorial where I can learn to handle the Fog Tool?
Im not sure how to get the detail and density youre after with env fog, but I was playing with it today to get some smokey stuff surrounding area lights. This was in Maya but I plugged 3d textures into the fog colour instead of transparency. It took way way longer to render connected to transparency. I also had to spend a while dialing in the scale of the noise as by default it can come in way too small which also kills the render time.
I was using Maya, so Im not sure how it translates to cinema 4d…but if I used one noise, it needed a scale value of 40, if I used a different one, it needed a scale value of 0.1. So it really depends on the type of noise youre plugging in. I would make a very simple scene first, of just a light in some fog, and just get the system working on a very small and fast test scene. Attached is a screen grab from my test scene…it looks nothing like what youre trying to do, but I needed to try a lot of different scales to get one that worked. You could also plug in a checker material in the fog so you know for sure that the effect is working.
here is a quick test, I’ve scattered a few trees from Cosmos library over a landscape object, for the fog I use some free clouds VDB files.
In case you want to try this option remember to rise the render/shadows step percentage to speedup the render;)
