Fog?
It feels like its a century since last time i needed to use some good old fog, and all the standard varieties behaves like complete maniacs with the vray camera is there a plugin available nowadays or what?
Nope, not yet. Its a feature I think is being worked on. There are 2 ways around it. Do it as a scanline render and composite in post, or dont use the vray physical camera and it works like normal. :slight_smile:
Actually, you can you the vraycam if you use vraycolor in the fog env color map and punch up the rgb multiplier a lot.
Works just fine that way.
Any possibility of posting a simple example?
