forest color doesnt work with GPU DR
Forest color seems to work perfect (Forest Pack Pro 6.1.2.570,max 2017, Vray 36004 RT GPU production rendering) as long as there is distributed rendering switched off… If it is on forest objects are the same color imidiately… Please advice on how to achive forest color effect with GPU render farm?
Hello!
We have a similar issue that is already fixed in V-Ray Next. It’s probably the same case but we’ll know it after we take a look into your exact scene setup for other potential causes. You can send a simplified example scene to the support team or directly to me - margarita.stoeva@chaosgroup.com
Margarita
Hello!
Thank you for the scene - it was perfect to demonstrate the case!
The actual issue is fixed in V-Ray Next so I recommend upgrading to it.
Your scene setup is correct and I can’t think of any smart move to make it work with you current version of V-Ray.
Margarita
