Forest Glowing
What would cause these Enscape trees to glow like this? I have tried to play with various Visual Settings and nothing seems to fix it. I opened a new file and experimented with the Escape proxies and the new file doesn’t seem to do this.
Had simillar issue some time ago.. issue was for me that the file was too big.. to many trees and ENS stopped calculating shadows for some part of trees.. For me hiding everything that was not in the field of view helped..
You can see that in second image trees far back (top left) have no shadows and appear brighter
@ValeroStudio , basically what Tomasz above stated - You are running into a limit project size and complexity wise, which is why some shadows may stop rendering, as seen in your scene. We can only recommend reducing the ground plane in size, removing some objects, or reducing the complexity of some structures.
Let me know if that doesn’t do the trick.
Is it a physical model size thing or a quantity of objects thing? I turned off almost everything in my file and I still have the issue, but when I copy and paste just the trees and site into a new file, they render with shadows.
