Forest Ivy not rendering animation
Hi. After the update 12. Update 1 the forest Ivy is not updating the animation when rendering. But it does in IR mode and I move the timeline. Is there a hotfix for this?
I was able to reproduce this issue on my end. I have logged it in our system to be further investigated by our devs. I found that this works fine with Corona 11 HF 2 and Corona 12 HF 1. If this feature is very critical for you to use then I would suggest downgrading to Corona 11 HF 2 or Corona 12 HF 1 for the moment to make it work.
https://www.chaos.com/corona/3ds-max/download/old
(Report ID=CMAX-1418)
Ok thank you. I might just do that.
Hi again. I cant find Corona 12 hotfix 1. its not available on the download page. and the topics here on the forum just refers to the website. latest I can find is 11 with hotfix
If you need any other installer that is not on the website. please contact us by submitting a support ticket.
https://support.chaos.com/hc/en-us/requests/new
It is already available in older version download page.
This is fixed in the newest daily build of Corona which will be released as Corona 12 Update 1 Hotfix 1:
https://forum.corona-renderer.com/ Chaos Corona 13 for 3ds Max - Daily Builds Changelog #msg230430
