Forest Pack Delay
Hello, when use live link and forest pack tools, changing parameters in Forest pack, Causes the software to lock for a while.
The delay depends on the number of instances you have.
If you could temporarily reduce them while modifying parameters, it might be faster.
Which software, 3dsMax or Vantage ?
Greetings,
Vladimir Nedev
no problem in vantage, the scene is simple and my hardware is RTX3090 24G. when changing parameters in the forest (in live mode with vantage) 3dsmax makes crashes for a while.
when i stop live link, it be fine and ok
Since it’s 3ds Max that gets locked, this must be caused by the translation that V-Ray for 3ds Max does - from a ForestPro object to internal V-Ray scene instances.
Not sure if anything can be done about it, but it’s something that our V-Ray for 3ds Max team is probably aware of.
Greetings,
Vladimir Nedev
