forest pack edge mode
i tried to use fores pack edge mode to easyly fit the borders but it does no work! Any suggestions? Im using the newest version of corona and forest pack!
oh, ok is working perfekt by rendering. only in viewport the effect is no visible! is always so?
You can turn the effect on in the viewport but it slows the display down so it is off by default.
ok thanks! And how can i turn on the effect in viewport before rendering?
By right-clicking on the edge radio button if I remember
i mean this!
Correct, by default you’ll only see it in Render. It also if i recall only works if the FP object is applied to a spline and not a surface? Problem there is that it won’t apply to a spline that has rolling contours on the interior.
me too … Have you tried to right click on it ?
