Forest pack - Tint variations
Hi guys,
I have problem to use the Material Tint variations with Corona. It is not working… i don’t see any difference.
Can you please suggest me how do you make a color variations on the leafs of the tree or on the grass ?
I saw a tutorial about MultiMap Color Randomization, but i didn’t find a solution.
If you use a special trick or Material Corona.
Maybe a i do stupid mistake.
Thanks in advance,
Hi, you need to use the “forest” material or map. See attachments. Looks like it is compatible with Corona mtl.
Thanks a lot Maru,
I will try soon, but i need to convert all the trees in Forest material.
Ciao
P
Yes, you will need to update the material/map. I am using the lite version. The tree I loaded had a standard material applied, with just the color used as diffuse. Too bad it is not using Corona mtls, but maybe it’s just a limitation of the lite version? Or is it dependent on the specific model?
