Anyone having crashes with 3dsMax2018.3 ForestPro and the latest VRay? Occurs when you bring up the material selector.
Just to be sure - what are your Forest Pro and V-Ray versions?
Apart from that - when Max crashes - it will create a crash dump file called 3dsmax_minidump.dmp in your temp folder (%temp% in windows explorer). Can you send one such dump file to our support.
Yavor
Problem was with VRay VRay361.01 and ForestPro 5.40…Not fixed with ForestPro 5.41
I think you have to use original V-Ray 3.60.03, not nightly builds or you can get into troubles. iToo makes compatible versions of Forest Pack with final builds of VRay only.
Yes generally nightlies might have problems with ForestPro. Can you tell me the exact nightly version - it can be checked with the MAXScript function vrayVersion().
3.61.01", “27448”, "b54d89be, to be exact, thanks for everyones help
