Forum changes...?
How come they limited the number of image links to 4 in the main forums? Is this a global forum restriction or can it be changed in the CP? It’s fairly limiting and also causes one to have to manually change the post instead of cutting and pasting from other sites.
-Richard
Well, one could always use imageshack or similar, and add as many images as wished.
Or not?
Hello Richard,
I will check this with the forum admin (I was not aware of this limitation)…
Thanks, Vlado - seems like a silly limitation since the images aren’t hosted on your server anyway. Thanks for looking into it!
-Richard
So this restriction should be removed now.
Awesome - it does! Just added more images to my last post: http://www.chaoticdimension.com/forums/vbulletin/showthread.php?t=41102
Thanks, Vlado.
-Richard
