Forum - Wishlist
Ok,
it is not conneceted to Vray… but to the forum:
in the search page of the forum, it could be great to sort the results also by “Date Posted” (because sometimes there are too old discussions connected to very old-vray versions)
Thank you :slight_smile:
Re: Forum - Wishlist
The advanced search should help - you can specify dates, as well as specify the order that you see the search results… Look over to the left under search, there’s a link to “advanced search”
thx :smile:
I actually avoid using the forum search all together, and just use google to search the site, like this:
rendering large scenes site:forum.asgvis.com
Not sure exactly what the reason is for a seperate forum and site password. As a “wish” item, it would be nice to only have to log in once. Right now, if I want to check out a Vismat I have to log into the site with one login, and then login with a different username and login for the forums. Maybe it’s just me because I created a Chaos Group login right during the switch, and I could have the same for both, idk. But I’m guessing I would still have to login twice. Just a wish to make things easier.
