Can you direct me to some info on how to use the new Vray Frame Buffer background image file option?
thank you
thank you
You enable the background image, then select a file to load as background, and that’s pretty much it.
This is only for preview in the VFB; the background image will not be actually saved into the final render.
thank you for your reply. If I understand correctly - to enable the background image, I click the button “Use Background Image” in the Vray Frame Buffer. I get that. I cannot find how to choose/select the background image that I want to display. IOW no dialog box/file selector opens.
So my question is - How do I select the file to load?
thank you for your help!
that’s what I was missing. I needed to open the color corrections panel.
Thank You!
