Frame Buffer Duplicate
Is there a way to duplicate the VRay frame buffer but not to Max’s frame buffer ? I am using LWF and it duplicates washed out.
n
Am I missing something obvious ?
I am, missing something obvious but what is it ??!
You might have the max Gammas turned on, and those’d work only in the Max VFB, hence the washing out.
Try and see if it’s the case :slight_smile:
Lele
Re: Frame Buffer Duplicate
Nope. Internally V-Ray supports only one frame buffer.> I am using LWF and it duplicates washed out.You are probably also using the 3dsmax gamma setting, which applies additional correction on the displayed image.
I don’t want to sound an ejit but where do I find the Max gamma setting ?
If you use LWF but leave the colormapping at linear 1.0 1.0 and use the SRGB button of vray frame buffer instead, when u duplicate the window to a max window, it displays the image correctly and not double corrected and therefore washed out.
So, just to see the duplicate frame buffer I have to change the color mapping from Gamma Correction to Linear ? It works but seems strange.
n
Keep in mind that if you do that, you image wont be gamma corrected straight from render, so if you save and open the image in photoshop, it will look darker and u will have to compensate the gamma by applying a 2.2 gamma correction in post. In fact, there’s no need to use gamma correction color mapping anymore, the SRGB button looks much more convenient to me and less cumbersome than the old curve correction method…
I have reverted back to using Gamma Correction so, cannot make a duplicate of the frame buffer. This is a real pain because I use the duplicate function alot to compare images when developing a project.
