Frame Number Error
http://www.kesslerdesign.com/VRayerror.gif
http://www.kesslerdesign.com/vraylog.zip
1.46.15: Using QMC, DR, either VFB or MFB. Vray will not render the selected frames using the “frames” or “range” values. Instead it either selects frame 160 or 320 either of which do not exist in the file.
Will work when not using DR.
Thanks.
EDIT: I take that back. It will not render any frames of the sequence. It remains stuck on 160 or 320 no matter what you select in the frame dialog. This is a camera that was created with the “Camera Animator” script and has an animated “Technical Camera” modifier.
Rendering of frame sequences is not currently supported in DR mode.
