Frame stamp options
Is there a way I can call render settings, such as the noise threshold, into the frame stamp? Or is there only %primitives, %rendertime, and %vrayversion?
Thanks!
Hi, we do not support various settings in the frame stamp, but the string is MaxScript accessible so it is not impossible. There is a script that might help, it registers a function that updates the frame stamp on every render beginning. It must be run once. And the whole frame stamp is changed in it so it may need to be modified.
Alexander
stampupdate.zip (447 Bytes)
Btw we do support some other stamp variables that you can see if you click on the ‘%’ button in the VFB. They are also listed here:
