this one is a little bit tricky to reproduce.
I found that if I render bigger resolutions, say 4K up, the interaction in the framebuffer becomes very laggy:
e.g. zooming in/out, the buckets don’t update, switching AOVs, etc.
sometimes the framebuffer doesn’t updates buckets for minutes…
Is this a known issue or does somebody else have it? Or is it only me?
I would like to kinda make some screen captures, but at the moment the projects are confidential. I hope i’ll find time to setup something to reproduce the issue
Is this problems appear in IPR mode? I realised that IPR in Houdini is rendered in the same resolution like production render. This is suboptimal to say the least… In 3ds Max IPR resoulution is dependant on IPR window size…
